Date/Time: Fri, 10 Jan 2025 04:56:17 +0000
Chart replay stalling
View Count: 609
[2016-08-22 02:17:39] |
User50927 - Posts: 91 |
Chart replay has began stalling and/or moving slower since I upgraded to both the current and the pre-release version of the software today - everything worked fine as of last week's upgrade. It might be a minor software incompatibility issue with the Vimeo video player (it's all I can think of), but I've never had problems playing videos on one screen while replaying charts on another monitor before.
[2016-08-22 21:55:41] |
Nothing has changed with replay. We do not believe that this has anything to do with the new version. Does not make sense. this section here describes a possible problem for what you see: http://www.sierrachart.com/index.php?page=doc/ReplayChart.html#HistoricalIntradayDataRecordTimeframeEffect Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
