Date/Time: Fri, 10 Jan 2025 04:18:58 +0000
TPO setting question (Letter sequence)
View Count: 744
[2016-08-20 23:59:21] |
NumbersBars - Posts: 141 |
I am setting weekly TPO chart with Sub Period price display style = Letter However,I noticed letters displayed are always reset back to"A" after"E" period. I have attached the screenshot of TPO and setting for your reference. Is there any setting I can change in order to display continuous letter sequence? i.e A-Z? |
Attachment Deleted. Private File |
[2016-08-22 09:57:08] |
There is not proper support for using the TPO letters across time periods of greater than 1 day in an Intraday TPO Profile chart. This will need to be added.
