Date/Time: Fri, 10 Jan 2025 19:58:49 +0000
Historic data Not loading
View Count: 1005
[2016-08-20 11:59:39]
garyw - Posts: 5
My historic data will not load , It says historic data skipped .
Gary
[2016-08-20 17:27:34]
User449971 - Posts: 3
I want to load at 3 years back to test but it loads only 6 months of data.
[2016-08-21 11:51:40]
In response to post #1, tell us one of the symbols you are having a problem with and provide a copy of the Message Log following these instructions here:
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
In response to post #2, refer to:
http://www.sierrachart.com/index.php?page=doc/HistoricalIntradayData.html#DownloadingViewingMoreHistoricalIntradayData
[2016-08-22 15:36:10]
So as far as I checked maximum days to load is 186 (half a year) so for me it is practically useless. If I would know I would not buy access, you should advertise this fact.
Is this a maximum from all your possible sources?
[2016-08-22 17:00:16]
In response to post #4, what is this exact symbol you are asking about?
And also you are on the Sierra Chart service package 1 which does not provide historical data for some symbols. The package is considered discontinued. We can change your service package to 3.
Date Time Of Last Edit: 2016-08-22 17:00:27
[2016-08-22 17:21:57]
Thank you for your answer. I would like to have:
EUR/USD, GBP/USD, GBP/JPY.
[2016-08-22 17:28:54]
There is historical Intraday data back to December 2007 for these symbols. You just need to follow through the step-by-step instructions here:
Make sure you do that.
Also the symbols do not contain a /. Example of correct symbol: EURUSD
Date Time Of Last Edit: 2016-08-22 17:29:50
[2016-08-22 23:46:32]
garyw - Posts: 5
I have a chart book of daily and a few weekly ES, NQ, ZB, YM,
It was missing 3 days of data , and on my INTRAD day Charts the 3 line break chart was blank all other charts were
working .last weekk I could not log in because of trans act ERROR .
yesterday I Downloaded new version of SC
Today my Daily charts loaded and the 3 line break is working.
I don't Know ???
Thank You ..
Gary W
[2016-08-23 02:37:44]
So is everything OK now?
[2016-08-23 11:39:35]
garyw - Posts: 5
as of now Yes.
Thank you
[2016-10-03 02:47:57]
User47068 - Posts: 15
I am now getting data (the Chart Settings had reverted to Historical when they should have been Intraday; is that usual?).
However, it is still not pulling in my open positions (I trade with GAIN Capital).
Is that a server or settings issue inside SC and some change you/they made?
Any help would be appreciated.
[2016-10-03 03:51:19]
No. You mean an Intraday chart changed to a Historical Daily chart?
Regarding Positions, refer to:
http://www.sierrachart.com/index.php?page=doc/TradeStatusWindows.html#IncorrectlyReportedTradePosition
Date Time Of Last Edit: 2016-10-03 03:51:38
