Date/Time: Fri, 10 Jan 2025 04:27:54 +0000
Realtime Feed - Ninja Trader
View Count: 873
[2016-08-20 07:11:54] |
User78442 - Posts: 260 |
Hi, I understand that the SC Realtime Exchange Data is provided via Barchart - Can this feed be used in Ninja Trader via the External Feed option via a Barchart login?
[2016-08-20 19:27:55] |
No.
