Date/Time: Fri, 10 Jan 2025 04:29:01 +0000
PNL Displayed in Currency - Advanced Settings 2
View Count: 859
[2016-08-19 20:03:21]
infpz - Posts: 826
Is there a global setting for this option? (rather than the default, which is points)
[2016-08-20 01:28:16]
No there is no global setting. However, refer to this page:
http://www.sierrachart.com/index.php?page=doc/helpdetails20.html
Date Time Of Last Edit: 2016-08-20 01:28:49
[2016-08-22 11:06:07]
infpz - Posts: 826
Thanks, I suppose I am to make the change to the underlying symbol here, correct? http://www.sierrachart.com/index.php?page=doc/GlobalSymbolSettings.php
Can you point me in the right direction?
[2016-08-22 16:42:47]
No, the Profit/Loss Format cannot be controlled through the Global Symbol Settings.
