Date/Time: Fri, 10 Jan 2025 04:07:59 +0000
Re: OCO orders in different markets
View Count: 648
[2016-08-19 19:38:13] |
User292365 - Posts: 20 |
Hello, Is there a way that I can set an OCO order but in different markets? In other words, I have an order that will trigger in Crude Oil if price in the Crude Oil reaches a certain target and I also have an order in the Nasdaq that will trigger if price in the Nasdaq reaches a certain target. Whichever one of these entry orders gets triggered first, this causes the other entry order to get cancelled. |
[2016-08-20 01:16:39] |
You can do this but it requires custom programming with ACSIL: http://www.sierrachart.com/index.php?page=doc/ACSILTrading.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
