Date/Time: Thu, 19 Sep 2024 21:45:06 +0000
data feed diconnecting me
View Count: 1373
[2013-07-21 23:25:27] |
dst656 - Posts: 16 |
every 25 minutes or so the i keep getting disconnected from the data feed (zen fire ). i checked with the data feed people and they say everything is ok on their end. do i need to do something on my end ? once i connect it's ok but then within 30 min it happens again.
[2013-07-21 23:59:38] |
Refer to the Trading Requirement section at the bottom of this page here: http://www.sierrachart.com/index.php?l=doc/Rithmic.php#TradingRequirement Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
