Date/Time: Fri, 10 Jan 2025 04:00:11 +0000
Pull up detached chart windows via hot key?
View Count: 788
[2016-08-19 14:39:32]
trader1 - Posts: 128
Can I pull up detached chart windows using a hot keys?
Thanks.
[2016-08-19 16:54:12]
We do not understand what you mean.
[2016-08-19 19:31:49]
Let's say I have some detached chart windows on various monitors that are hidden from view due to being minimized or because other windows are covering them. Is there a way for me to pull one of them to the forefront using a hotkey?
[2016-08-19 21:00:32]
No, this is not supported. You need to select them from the Windows Taskbar.
