Date/Time: Fri, 10 Jan 2025 03:53:03 +0000
GetHighest and GetLowest Function Prototypes
View Count: 1315
[2016-08-18 16:16:07]
User147461 - Posts: 33
Would you please consider adding the GetHighest and GetLowest function prototypes in the scstudyfunctions.h file?
float GetHighest(SCFloatArrayRef In, int StartIndex, int Length);
float GetLowest(SCFloatArrayRef In, int StartIndex, int Length);
Thank you!
[2016-08-18 17:34:29]
These are already member functions of the ACSIL interface:
http://www.sierrachart.com/index.php?page=doc/ACSIL_Members_Functions.html
[2016-08-18 20:25:01]
I'm calling the GetHighest and GetLowest functions directly from a separate MyFunctions.cpp file and not from my main MyStudies.cpp file.
It would just be more convenient for me to have these prototypes included in the scstudyfunctions.h file if it causes no harm no foul.
These are also member functions of the ACSIL interface which have corresponding prototypes included in the scstudyfunctions.h file.
sc.GetSummation
sc.GetTrueHigh
sc.GetTrueLow
sc.GetTrueRange
Prototypes included in the scstudyfunctions.h file:
float GetSummation(SCFloatArrayRef In,int Index,int Length);
float GetTrueHigh(SCBaseDataRef BaseDataIn, int Index);
float GetTrueLow(SCBaseDataRef BaseDataIn, int Index);
float GetTrueRange(SCBaseDataRef BaseDataIn, int Index);
Thank you for reconsidering!
[2016-08-19 05:08:29]
This is definitely not something that we would do. It is not consistent with the overall design.
You need to do this:
http://www.sierrachart.com/index.php?page=doc/ACSILProgrammingConcepts.html#PassingACSILMembers
Date Time Of Last Edit: 2016-08-19 05:08:47
