Date/Time: Fri, 10 Jan 2025 03:40:34 +0000
properties
View Count: 655
[2016-08-18 16:14:49] |
User159327 - Posts: 1 |
How can I copy settings such as custom control bars and tool configurations to a new and separate install of SC?
[2016-08-18 17:35:38] |
This is documented here: Https://www.sierrachart.com/index.php?l=helpdetails15.html These are all contained within the Sierra3.Cfg file Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
