Date/Time: Thu, 19 Sep 2024 21:33:37 +0000
CTS FIX questions
View Count: 1500
[2013-07-21 03:33:47] |
joshtrader - Posts: 485 |
I am in a position where I can use either CTS, Rithmic, or TT. I have noticed some serious latency issues with Rithmic through SC. In the past I used CTS and also noticed some lag but it was with the pre-FIX implementation. Has anyone used CTS (PRODUCTION feed only, NOT SIM) with the new FIX implementation in SC? If so, can you comment on differences? SC Engineering, in your testing can you briefly comment on differences in latency/speed or anything else that would alter the user experience in any way? |
[2013-07-21 05:09:07] |
CTS FIX should be released in 1 or 2 more days and then you can test. We have not paid close attention to latency with the CTS FIX data feed. Hopefully, it will be the same. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-07-21 05:09:37
