Date/Time: Fri, 10 Jan 2025 13:40:05 +0000
How to create simple buy order in spreadsheet trading?
View Count: 807
[2016-08-18 14:09:27] |
User600819 - Posts: 43 |
I'm trading a 5 minute bar chart. The signal is ID3.SG3 for Long Entry and ID3.SG4 for Short Entry. How do I create the syntax in spreadsheet trading to say "go long at next bar open after previous bar gives ID3.SG3 signal?". I've attached a screenshot. I want to go long after the red volume bar. I can't seem to figure it out. Thanks! |
Private File |
[2016-08-18 17:54:25] |
You need to set this Spreadsheet System for Trading study Input to Yes: http://www.sierrachart.com/index.php?page=doc/SystemsAlerts.php#SignalOnlyonBarClose Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-09-16 19:43:02
[2016-09-16 19:34:59] |
I am still unclear how to create a buy signal. I understand inputting yes so the trade initiates after the close of the previous bar. From the attachment my signals are based on volume which are highlighted. What do I put in the spreadsheet trading to say go long after volume bar turns red? IG3.SG3 is a red volume bar. I know how to initiate entries for moving average crosses or if price crosses a level but I don't know how to enter entries based on when volume turns a specific color. Thanks so much
[2016-09-16 19:44:48] |
There was a slight mistake in post #2, it was meant to say: You need to set this Spreadsheet System for Trading study Input to Yes:
http://www.sierrachart.com/index.php?page=doc/SystemsAlerts.php#SignalOnlyonBarClose You can only work with actual numeric values. Not colors. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-09-16 19:45:16
