Date/Time: Fri, 10 Jan 2025 03:46:10 +0000
TTNET OCO Order
View Count: 819
[2016-08-18 00:15:54] |
User150371 - Posts: 70 |
Hello.Can you clarify something ? I understand that with TTNET data feed, OCO orders are not held server side. But I seem to remember reading somewhere on this Support Board or in Documentation that Sierrachart does hold the orders server side, so that even if disconnected a Stop loss will be cancelled if the Profit target is filled. Do I remember correctly ? Thank you.
[2016-08-18 04:38:08] |
There is no server-side OCO with TT, but there is this feature which is an alternative: http://www.sierrachart.com/index.php?page=doc/GlobalTradeSettings.html#HoldLimitAttachedOrders Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
