Date/Time: Thu, 09 Jan 2025 19:38:05 +0000
Changes on processing bar closed?
View Count: 830
[2016-08-16 15:35:14]
@sstfrederik - Posts: 404
Hi
I found that previously when a bar closed the sc.Index of the closing bar could be used to reference that closed bar.
During this week I see that this has changed. Right now the sc.Index of the new bar is used at the time a bar is in closed status.
Is this permanent? Had to change a number of strategies to have them work as intended again.
I did not do a version comparison yet.
Thanks.
Date Time Of Last Edit: 2016-08-16 15:58:27
[2016-08-16 16:27:54]
This cannot possibly be true. Something like this would never change. Otherwise, this would have very serious consequence for the overall functioning of studies. This definitely has not changed.
Refer to the documentation here:
http://www.sierrachart.com/index.php?page=doc/ACS_ArraysAndLooping.html
[2016-08-16 16:33:07]
I agree it shouldn't.
I will reduce what I see to a simple code example and do a version comparison and get back here.
[2016-08-16 16:59:41]
We do not need any code example. Nothing has changed with this.
