Date/Time: Thu, 09 Jan 2025 19:39:11 +0000
IB filled display incorrectly
View Count: 758
[2016-08-15 18:18:14] |
User269983 - Posts: 31 |
I don't know what I did wrong but on the chart, the filled price is not display correctly. Example: Filled at 2189.50 but shows 2188.54 on the chart. The trade activity log shows 2189.50. Just the chart is not correct. See attached. |
[2016-08-15 18:29:21] |
Refer to: http://www.sierrachart.com/index.php?page=doc/TradeStatusWindows.html#HowAvgPricePositionsCalcUsed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-08-15 18:34:51] |
Sorry, I made a typo on the average. I know where the discrepancy came from. The price on the chart included the commission. $2.03/$50.00 is 0.04 point. How do I exclude commission from the calculation? |
[2016-08-15 18:58:33] |
Specifically refer to this section for instructions on what to do: http://www.sierrachart.com/index.php?page=doc/TradeStatusWindows.html#TradeServiceProvidedAveragePrice Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
