Date/Time: Mon, 13 Jan 2025 17:03:25 +0000
Linking Charts across Chart Books
View Count: 2186
[2016-08-15 17:05:12] |
User78442 - Posts: 260 |
Can you link charts/copy chart drawings across chartbooks??
[2016-08-15 18:37:01] |
No this is not supported and there are no plans for this.
[2017-05-03 16:58:18] |
Another user made reference to this thread. We made a mistake in our answer. Chart Linking is not supported across Chartbooks. But it is supported to copy Chart Drawings.: http://www.sierrachart.com/index.php?page=doc/helpdetails72.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
