Date/Time: Thu, 09 Jan 2025 20:04:25 +0000
Spreadsheet system for trading
View Count: 902
[2016-08-15 14:55:29]
User14682 - Posts: 83
Currenty I have this formula: =CROSSFROMBELOW( ID1.SG1@3:ID1.SG1@4, ID3.SG1@3:ID3.SG1@4)
How do I indicate that ID5.SG1 also needs to be > ID6.SG1
[2016-08-15 18:40:30]
You just need to use the AND function:
http://www.sierrachart.com/index.php?page=doc/SpreadsheetFunctions.html
[2016-08-15 19:07:11]
WHATS WRONG WITH THIS?
=OR(AND(CROSSFROMBELOW(ID1.SG1@3:ID1.SG1@4,ID3.SG1@3:ID3.SG1@4),AND(ID5.SG1@3>1D6.SGQ@3))
MY FORMULAS USED TO LOOK LIKE THIS... CAN I NO LONGER USE THE COLUMN?
=OR(AND(AA3>AG3,AA4<AG4,AG3>AC3,AG3>AE3,AG3>AI3),AND(AA3>AE3,AA4<AE4,AE3>AC3,AE3>AG3,AE3>AI3),AND(AA3>AI3,AA4<AI4,AI3>AC3,AI3>AE3,AI3>AG3),AND(AA3>AC3,AA4<AC4,AC3>AE3,AC3>AG3,AC3>AI3))
[2016-08-15 21:02:33]
Sawtooth - Posts: 4147
Yes, you can use either format.
There are two advantages to using the ID#.SG#@# format:
1) You can rearrange studies in the Studies to Graph list without messing up your formulas.
2) You can insert/delete columns without messing up your formulas (if you have enough spare Formula Columns before you insert).
Suggestion: Use the ID#.SG#@# format when referencing study outputs, and use the alpha column format when referencing other Formula Columns.
Date Time Of Last Edit: 2016-08-15 23:05:13
[2016-08-16 18:06:12]
Crudeoilist - Posts: 18
I don't know what you are trying to do so my reply might not be of any help. But what I do is use the color bar for alerts study and code in what ever i need to color the bar as a buy or sell signal. then in the spreadsheet for trading study i simply refer it to the color bar study as a true/false statement. but then again, my code is not really that long. hope this helps
[2016-08-16 18:13:07]
IS THERE A WAY TO IMPORT MY OLD CHARTS INTO SIERRA CHART?
[2016-08-16 18:47:25]
Corrected formula:
=AND(CROSSFROMBELOW(ID1.SG1@3:ID1.SG1@4,ID3.SG1@3:ID3.SG1@4),ID5.SG1@3>1D6.SGQ@3)
Yes you can still use direct referencing of the columns.
Or you can use this format like you did in the first formula:
http://www.sierrachart.com/index.php?page=doc/Spreadsheets.html#ReferencesStudySubgraphColumnsSpreadsheetStudy
Yes. Refer to:
http://www.sierrachart.com/index.php?page=doc/Chartbooks.html#CopyChartbook
Date Time Of Last Edit: 2016-08-16 18:48:11
