Date/Time: Thu, 19 Sep 2024 22:11:26 +0000
Bollinger on Onebalance volume
View Count: 1462
[2013-07-20 05:17:56] |
User45578 - Posts: 49 |
i want getting Bollinger Bands on ONEBALACEVOLUME ?I dont find ONEBALANCEVOLUME on the pop up of Bollinger Band,how i can get it?
[2013-07-22 03:50:54] |
You need to use the Based On setting in the Study Settings window for the Bollinger Bands study. Refer to: http://www.sierrachart.com/index.php?l=doc/doc_ChartStudies.html#BasedOn You also need to be sure to add the On Balance Volume study to the chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
