Date/Time: Fri, 10 Jan 2025 03:49:27 +0000
Bollingerband problem
View Count: 887
[2016-08-13 17:28:51] |
User378205 - Posts: 28 |
My bollingerband indicator looks wrong to me. Can you check on this? This is on default setting |
20160814_022743.png / V - Attached On 2016-08-13 17:28:19 UTC - Size: 33.14 KB - 259 views Attachment Deleted. |
[2016-08-13 18:28:50] |
TH.555 - Posts: 38 |
Same problem with the current version (1453). I rollback to an older version (1445). |
[2016-08-13 23:24:10] |
The Bollinger Bands study is completely fine and there has been no changes to it for years. There is no problem with it. We do not have any idea what either of you are talking about here. There is insufficient information here. We compared it back to version 1414 and is identical to what you see in 1453, as we would expect. Once again there is no problem with it whatsoever. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-08-14 14:53:11] |
First screenshot - Bollinger Bands - Version 1445 http://www.sierrachart.com/image.php?Image=1471185911978.png Second screenshot - Bollinger Bands - Version 1453 http://www.sierrachart.com/image.php?Image=1471186072378.png |
[2016-08-14 20:55:18] |
We will look into this. The only thing that has changed is we are using a new Microsoft compiler. So that must be the reason for the problem. Otherwise, there are no changes. In our testing we do not see any differences. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-08-15 06:50:01] |
I have downgraded mine to 1448 and bollingerband indicator works again. You guys might want to retest this otherwise I would never be able to update to a new version
[2016-08-19 13:24:41] |
Bollingerband works properly with latest version
[2016-08-19 13:37:44] |
OK with version 1454 - Thanks
[2016-08-19 16:37:59] |
Yes this is true, we did find the reason for the problem. It had to do with a change in the Microsoft compiler.
