Date/Time: Thu, 09 Jan 2025 19:55:49 +0000
Volume profile for studies other than candlesticks
View Count: 684
[2016-08-13 11:56:30] |
User560062 - Posts: 100 |
Is it possible to add a volume profile for studies such as volume in sierra? I come from IRT and used to find this very helpful to find out what is within normal range and not? Thank you |
[2016-08-13 12:02:01] |
No, this is not supported.
[2016-08-13 12:25:19] |
Is there any other way to check what's normal and what isnt ?
