Date/Time: Thu, 09 Jan 2025 19:47:12 +0000
chart replay play settings changes speed during playback
View Count: 820
[2016-08-12 17:49:58]
melan21 - Posts: 2
When I replay a chartbook with two charts, one is a inverted price of the other by the multiple x 1 study,
the replay changes from my setting of 6 to 60 after a minute or so in real time.
So as its playing all of a sudden it goes really fast. I have to pause, change the setting back to 6, and play it again.
I checked off for all charts in the chart book, skip empty periods, and its a standard replay
[2016-08-12 17:52:53]
You must be inadvertently changing the speed. It is impossible for the speed to change on its own and there has never been a known case of this. That we are 100 percent certain of.
Remove the focus from the Speed control on the Replay Window after setting it.
[2016-08-12 18:28:05]
melan21 - Posts: 2
Ive tried what you have said and when I leave it for a minute the playback does change speeds when I am not touching the computer.
If you want you can have remote access to see for yourself
[2016-08-12 18:55:57]
We see a condition where when you adjust the Replay Speed, the chart is not currently replaying, and then you close the Replay Window, the speed setting will not be saved. We will solve that.
