Date/Time: Thu, 09 Jan 2025 19:31:45 +0000
using the DOM to place a triggered limit order
View Count: 708
[2016-08-12 14:10:21] |
User295967 - Posts: 32 |
I would like to know if it is possible to place a triggered limit order in the DOM. For instance if the market is @ 5, and trades up to 10, I would like an order to be triggered placing a buy limit order @ 9. Conversely if the market is @ 10, and trades down to 5 I would like an order to be triggered placing a sell limit order @ 6. Can you please tell me if this is possible in the DOM? Thank you.
[2016-08-12 17:03:40] |
See if this study does what you require: Order Types: Triggered Limit Order Entry Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-08-12 17:03:58
