Date/Time: Sat, 03 Oct 2026 10:18:08 +0000
$TRIN
View Count: 2451
| [2013-07-19 18:44:01] |
| User54027 - Posts: 128 |
Hello, Please explain how it is possible to have a negative $Trin reading??? Rg, Justin http://www.sierrachart.com/image.php?l=1374259421931.png |
| [2013-07-19 18:54:16] |
There should not be negative values in the $TRIN data and we are looking into this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-07-19 18:54:33
| [2013-07-19 19:45:30] |
$TICK also looks suspicious, readings very high for sideways price action. Please confirm urgently that all your Dow internals data is accurate as incorrect readings on tick and trin is a massive problem
| [2013-07-19 21:12:19] |
We have contacted our data provider about $TICK also. It is their responsibility to look into these issues and correct them. $TICK does not look correct today either. So we see an issue with the symbols for today only. You also say "Dow internals". The Sierra Chart market statistics are not for the Dow. They are for the NYSE and NASDAQ. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
