Date/Time: Thu, 09 Jan 2025 19:31:38 +0000
Easiest way to set up Alerts
View Count: 2777
[2016-08-12 10:20:28] |
User554317 - Posts: 59 |
I find setting up alerts with SC very tedious. Ideally I'd just love to be able to right click on a price level on the chart and set an alert: at or above.../at or below... Is there an easier way to set up alerts? Perhaps a study? Thanks. |
[2016-08-12 17:47:31] |
There are various ways to set simple price alerts. In your case we think the best way is to use the Symbol Alerts feature: Alerts Manager: Symbol Alerts Just follow through the instructions. There are instructions for right clicking at the price level you want to set the alert at. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-08-12 18:17:51] |
Perfect that's exactly what I was after thank you. I like receiving emails as alert messages. Does this cost or does it only cost for sms alerts? Thanks again. |
[2016-08-12 18:27:45] |
There is no cost for Email alert messages. But there is a cost for SMS alert messages.
