Date/Time: Thu, 09 Jan 2025 19:34:11 +0000
Is the following log all ok?
View Count: 711
[2016-08-12 01:31:36]
GPST10 - Posts: 139
I'm getting this log hourly or so from Sierra. At beginning I set to update time from server option (IN THE GLOBAL TRADING SERVICE SETTING)but I changed it to local. I'm doing it myself with NIST srver. I thought this log would stop. Any way to set so it doesn't do it, asking this because it also shows some WINDOWS ERROR may be indicating the system can't access or adjust time on my machine.
Please Let me know.
LOG:
HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP X.X.X.XXX. | 2016-08-11 19:01:12
HTTP connection to www.sierrachart.com:80 (60) | Connected. | 2016-08-11 19:01:12
Received Date-time from server. Delay adjusted UTC Date-time: 2016-08-11 23:01:12.122. Round-trip delay: 00:00:00.217 | 2016-08-11 19:01:12
Error setting the system Date-time. Windows error code 1314: A required privilege is not held by the client. | 2016-08-11 19:01:12 *
HTTP connection to www.sierrachart.com:80 (60) | Closed. No error. | 2016-08-11 19:01:17
HTTP connection to www.sierrachart.com:80 (60) | Shutdown and closed. | 2016-08-11 19:01:17
[2016-08-12 04:57:25]
You need to disable this option:
General Settings Window: Periodically Set System Date-Time from Server (Global Settings >> General Settings >> General >> Update Intervals)
