Date/Time: Thu, 09 Jan 2025 19:59:09 +0000
TPO profile inquiry
View Count: 677
[2016-08-11 23:21:30] |
User867668 - Posts: 7 |
Is it possible to change the display letters of the TPO profile? For example my current charts the opening period of the ES pit session will be displayed as the letter "D" is it possible to change to the letter "X" instead and then have each period display incrementally a new letter. How can I accomplish that?
[2016-08-12 02:40:21] |
Yes you can do this. This is documented here: https://www.sierrachart.com/index.php?page=doc/TPOVolProfileCharts.html#CustomizeTPOLetters Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
