Date/Time: Thu, 09 Jan 2025 19:36:36 +0000
Including commission DOM PnL
View Count: 1604
[2016-08-11 15:41:09] |
User378205 - Posts: 28 |
I went to Global Symbol Settings for E-mini S&P500 Futures and I set my commission rate charged by AMP futures. Still DOM only shows PnL without commission rate. How can I include commission rate on my DOM PnL? |
[2016-08-11 17:04:15] |
This is not supported and there are no plans for this.
[2016-08-11 17:52:02] |
Then what is the purpose of setting commission rate under global symbol?
[2016-08-11 17:55:51] |
In the documentation it says it applies to the Trade Activity Log.
