Date/Time: Fri, 10 Jan 2025 03:56:00 +0000
linear regression
View Count: 1245
[2016-08-11 15:33:07] |
User472677 - Posts: 356 |
Hello, In study linear regression end channel, there is an input 'date and time'. I want start date to be always today at 9:30am. With over 100 charts open, it is not realistic to manually set a date in each chart every morning. How do I do this? A suggestion is a default value such as 0 means only today. As you know, I have always been respectful of you being busy and have been fine with certain enhancements to be done over the long term. This one is URGENT if it can not be done in the present version. thx |
[2016-08-12 04:51:19] |
We can do this. Just give us a couple of days.
[2016-08-12 11:45:32] |
thx
[2016-08-21 18:16:39] |
Hello, Thank you for excellent support. I am following up on linear regression end channel study setting to start today. Please let me know when it will be done so that I can plan accordingly. Thx |
[2016-08-23 02:51:26] |
This is now complete in version 1455 which is now available.
[2016-08-24 12:53:59] |
Thx, you guys are great!
