Date/Time: Thu, 09 Jan 2025 20:00:06 +0000
new tpo singles ?
View Count: 723
[2016-08-11 12:36:20] |
zippyzip - Posts: 293 |
something looks off , it plots singles but also plots non singles , can it be based on full profile and not just 30 min ? bottom 2 are correct but top ones are not singles
[2016-08-11 17:28:57] |
You need to understand what Singles are in this particular case. Refer to: https://www.sierrachart.com/index.php?page=doc/TPOVolProfileCharts.html#Inputs_ExtendSingles We have verified that this does function correctly. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
