Date/Time: Thu, 09 Jan 2025 20:00:44 +0000
Market breadth on list of symbols
View Count: 1329
[2016-08-11 05:07:18] |
User60579 - Posts: 41 |
Hi! Is it possible in Sierra chart having a list of 200 stock symbols and see how many of them are above 10 MA? And with that data plot a chart that updates every 5 minute during the day? Cheers |
[2016-08-11 05:55:35] |
The first part is possible. You can use the scanning feature which is documented here: https://www.sierrachart.com/index.php?page=doc/StudyChartAlertsAndScanning.php#Scanning As we understand the second question, the answer is no. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
