Date/Time: Thu, 09 Jan 2025 19:32:08 +0000
data box
View Count: 2143
[2016-08-11 02:53:46] |
User157806 - Posts: 71 |
Another question as well is when I activate the "Chart Values window" the values do not move when I move my mouse cursor across the candles. Am I using the wrong function perhaps? So basically I just need a simple daily value box to display the information such as O,H,L,C volume per bar when I am hovered over the candles with the mouse cursor.
[2016-08-11 05:33:40] |
Refer to: Chart Drawing Tools: Viewing Tool and Chart Data When Using Tools Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
