Date/Time: Thu, 09 Jan 2025 19:42:37 +0000
Charting Error with E7-201609-GLOBEX-USD
View Count: 730
[2016-08-11 01:04:23] |
rick e - Posts: 51 |
Hi folks, I'm back again. My Charts of the above offender were scaling say 1.1126 now they are scaling 11.126 and obviously producing an unreadable chart. I have looked at ways to fix this but can't come up with an answer. Any suggestion would be greatly appreciated - Thanks - Rick
[2016-08-11 10:26:49] |
Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Symbol Settings After that is done follow the instructions here to apply the Symbol Settings to the chart: Global Symbol Settings: Update/Apply Symbol Settings to Charts The chart should be OK after this, if not post an image of the chart following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
