Date/Time: Thu, 09 Jan 2025 19:41:53 +0000
message log interpretation
View Count: 1106
[2016-08-10 22:26:30] |
User705641 - Posts: 38 |
I keep getting this message log attached can you please tell me what it means Reading Internal Order ID file. | 2016-08-10 22:26:38 Reading Trade Orders file. | 2016-08-10 22:26:38 Reading Trade Positions file. | 2016-08-10 22:26:38 Software version: 1441 | 2016-08-10 22:26:38 Uses New Spreadsheets | 2016-08-10 22:26:38 Usage end date: 2016-08-28 | 2016-08-10 22:26:38 Enabled for: Advanced Features. | 2016-08-10 22:26:38 Enabled for: Advanced Features 2. | 2016-08-10 22:26:38 Enabled for: Sierra Chart Historical Data Service. | 2016-08-10 22:26:38 Allow Support for Sierra Chart Data Feeds is enabled. | 2016-08-10 22:26:38 Current selected Data/Trading service: SC Forex Data (FXCM) | 2016-08-10 22:26:38 Chart Update Interval: 500 | 2016-08-10 22:26:38 Time Zone: +01:00:00 (GMT+00BST+01,M3.5.0/01:00,M10.5.0/02:00) | 2016-08-10 22:26:38 2016-08-11 06:56:49 Local computer time | 2016-08-10 22:26:38 2016-08-10 21:26:49 Local computer time in UTC | 2016-08-10 22:26:38 2016-08-10 22:26:49 Local computer time in SC Time Zone | 2016-08-10 22:26:38 2016-08-10 21:26:43 Server time in UTC | 2016-08-10 22:26:38 Local computer UTC time and Server UTC time difference: 1 seconds. | 2016-08-10 22:26:38 Program path: C:\SierraChart\ | 2016-08-10 22:26:38 Data Files path: C:\SierraChart\Data\ | 2016-08-10 22:26:38 OS Version Number: 6.1 | 2016-08-10 22:26:38 Locale Setting: C | 2016-08-10 22:26:38 Created the DTC Protocol server. | 2016-08-10 22:26:38 Listening socket (764), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2016-08-10 22:26:38 * Listening socket (764), port 0 | Closed. | 2016-08-10 22:26:38 DTC Protocol Server failed to start listening on port 11099. | 2016-08-10 22:26:38 * Created the DTC Protocol historical data server. | 2016-08-10 22:26:38 Listening socket (764), port 0 | Failed to bind socket to 0.0.0.0:11098. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2016-08-10 22:26:38 * Listening socket (764), port 0 | Closed. | 2016-08-10 22:26:38 HD Server Manager | Error starting listening socket on port 11098 | 2016-08-10 22:26:38 (lines removed) Listening socket (1832), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2016-08-10 23:23:50 * Listening socket (1832), port 0 | Closed. | 2016-08-10 23:23:50 DTC Protocol Server failed to start listening on port 11099. | 2016-08-10 23:23:50 * Listening socket (1748), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2016-08-10 23:24:50 * Listening socket (1748), port 0 | Closed. | 2016-08-10 23:24:50 DTC Protocol Server failed to start listening on port 11099. | 2016-08-10 23:24:50 * Date Time Of Last Edit: 2016-08-11 22:55:15
[2016-08-11 16:58:08] |
Regarding this: Listening socket (1644), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2016-08-10 23:02:50 * Uncheck the following option: Global Settings >> Data/trade Service Settings >> SC Server Settings >> DTC Protocol Server >> Enable DTC Protocol Server. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
