Date/Time: Thu, 09 Jan 2025 20:01:50 +0000
Mouse Commands for Order Entry/Exit
View Count: 810
[2016-08-10 17:37:47] |
User231754 - Posts: 11 |
Is there a way i can use my Programmable Mouse for Order Placement with Entry/Exit ,and Stop Management like with the Keyboard Commands? I have not been able to find out this information before contacting you. I am very interested to be able to do this with a Programmable Mouse, and the available Buttons on the Mouse for Scalping. Basically i am in Need for Buy Market, Sell Market , and Flatten. But am interested to place other Orders, and be able to Manage the Trades without using Trade Window, or DOM. Thank you for any information on this matter. |
[2016-08-10 17:39:56] |
The method by which orders can be entered in Sierra Chart are currently documented. Therefore by making reference to the current documentation, and understanding your programmable Mouse, you can then determine if you can accomplish what you want. We cannot say more than that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-08-10 17:40:32
[2016-08-12 04:55:39] |
User948528 - Posts: 108 |
Yes it's possible, set up the trading keyboard shortcuts you need, then program your mouse to execute those keyboard shortcuts when you press the appropriate button.
