Date/Time: Thu, 09 Jan 2025 19:33:56 +0000
price scale movement
View Count: 1219
[2016-08-10 15:16:47]
aydex - Posts: 110
is there a setting to turn off the auto adjustmnt/movement the price scale does when a candle shows a lot of dynmics?
[2016-08-10 16:47:39]
Select Chart >> Scale. What is the Scale Range set to? Are you using Constant Range?
[2016-08-10 21:01:36]
aydex - Posts: 110
Will changing to constant prevent the behavior in attached, where I wasnt able to set my sell stop at a price because value was changing?
I think its most evident at 10 seconds in, when the cursor position's price is moved down by the candle getting longer
Private File
[2016-08-10 21:07:37]
aydex - Posts: 110
Does constant default to manual?
I cant seem to find these constant settings
Manual Mode
Keep The Last Bar Within View
Re-Center To The Last Bar On Every Update
Re-Center To The Last Price On Every Update
Re-Center When The Last Bar Exceeds A Certain Number Of Ticks From The Center
[2016-08-10 22:51:21]
aydex - Posts: 110
Setting for video was interactive scale . As it is the first time I have seen this setting, any sub interactive setting is at a default level
[2016-08-11 06:11:26]
You appear to have the Scale Range set to Constant Range and it looks like you have it re-centering on every chart update.
You should set the Scale Range to Automatic. Follow the instructions here:
Chart Scale and Scale Adjusting: Opening the Scale Settings Window for the Main Price Graph
[2016-08-11 06:35:31]
aydex - Posts: 110
Setting was interactive scale, automatic.
Assuming this is the default, "out of the box" setting
I would like to be able to hold the cursor at a price, be able to right click and set the order, whilst current candle is being dynamic, without having to move the mouse.
I have no problem adjusting vertical scale using the right edge at those times
is constant/manual suggested in these cases?
[2016-08-11 17:55:09]
We did look at the video and because there was a new low being made in the chart, that is why the chart automatically adjusted.
So we were mistaken that you are using a Constant Range scale. It did look like that though.
For the Scale Range use Constant Range and set the Constant Range Scale Mode to:
Keep The Last Bar Within View.
Refer to:
