Date/Time: Thu, 09 Jan 2025 19:39:39 +0000
1 Week Trial Extension
View Count: 824
[2016-08-10 13:41:05]
brcrude - Posts: 7
Hi, I would like to request a one week extension of Sierra Chart. Thank you.
[2016-08-10 16:47:06]
Sierra Chart - Max - Posts: 5778
Your account has been activated and/or reset.
If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu.
After your Sierra Chart usage time ends, you need to pay for additional usage time through "Help >> Add Usage Credit".
Sierra Chart Support
[2016-08-10 16:55:57]
This is done.
[2016-08-10 20:25:13]
brcrude - Posts: 7
Thank you.
