Date/Time: Thu, 09 Jan 2025 19:58:54 +0000
Wrong install directory for notepad++
View Count: 1071
[2016-08-10 11:35:11] |
User76539 - Posts: 18 |
Hi all, I am using Sierra Chart v1452. I have installed it to d: drive. I am trying to run Studies editor and I have received following message: There was an error starting the Advanced Custom Studies editor. C:\SierraChart\NPP\notepad++.exe "D:\SierraChart\ACS_Source\ExampleCustomStudies.cpp". Windows error code 2: The system cannot find the file specified. | 2016-08-09 07:38:08 * I have changed c: to d: drive in general settings for notepad++. I have restarted Sierra it did not help. I have rebooted PC and started Sierra again and it did not help. Sierra still wants to start notepad++ from drive C:. Can you help me pls.? Thank you mirek |
[2016-08-10 17:32:06] |
Update to the current version of Sierra Chart following these instructions: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate Follow the instructions here to set the text editor for custom studies: Error Starting the Advanced Custom Study Editor Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-08-11 12:52:09] |
Thank you a lot. It works now.
