Date/Time: Thu, 09 Jan 2025 20:08:30 +0000
1452 update issue
View Count: 898
[2016-08-10 01:48:45]
User20450 - Posts: 330
after doing the 1452 update i noticed this strange thing on most of my profile charts ,please let me know
image2016-08-09_21-47.jpg / V - Attached On 2016-08-10 01:48:26 UTC - Size: 51.47 KB - 317 views
[2016-08-10 03:59:28]
Log into this Support Board with the Sierra Chart account that you are using with Sierra Chart by selecting Help >> Support Board.
After that post a message again. Are you using Rithmic?
Date Time Of Last Edit: 2016-08-10 03:59:45
[2016-08-11 01:53:32]
zippyzip - Posts: 293
im using cqg data , dosent have it on older versions with same data , fwiw let me know , thanks
[2016-08-11 06:29:28]
Is this a Historical Daily or Intraday chart?
[2016-08-11 12:04:27]
intraday chart daily bars , 60 min bars , no matter what they all have this same thing
[2016-08-11 18:05:31]
Reduce the number of chart bars loaded into the chart. That will solve the problem.
[2016-08-12 02:12:00]
i dont follow , sorry , why do i have to limit bars plotted , that kinda defeats the purpose of the use
and it worked fine before update
let me know if this will be ongoing issue please
[2016-08-12 02:41:57]
Reduce the number of bars in the chart and see if that resolves the problem.
According to what we can tell, you have more than 100,000 bars in the chart.
[2016-08-12 02:53:40]
not sure where ur getting that info but i have 700 daily bars , thats it
[2016-08-12 04:59:11]
Therefore, this should not be a problem then.
Provide a Chartbook containing that single chart. Here are instructions:
We need to test it and understand the problem. Otherwise, we do not know exactly what the issue is.
