Date/Time: Wed, 27 Nov 2024 02:23:13 +0000
linked charts
View Count: 1206
[2013-07-19 14:33:34]
User39772 - Posts: 311
I have several linked charts open that show the same symbol in different time frames. When I move the cursor in one time frame all the charts in the other time frames start to scroll horizontally. Is there a way to disable this feature.
[2013-07-19 16:27:14]
Sierra Chart - Max - Posts: 5731
You will want to disable the Tools >> Global Cursor On option. For more information please see:
https://www.sierrachart.com/index.php?l=doc/doc_Tools.html#GlobalCursor
Sierra Chart Support
[2013-07-19 19:12:51]
Disable Tools >> Synchronize Charts and Synchronize Linked Charts Only.
[2014-07-19 10:36:45]
User72407 - Posts: 31
A follow-up question to this... in addition to the global cursor, is there a way to make multiple charts slew to the same time? For example, if I have a 5 minute chart showing 20 bars, and a 2 minute chart showing 20 bars, when I place the cursor on the 5 min outside the time range of the 2 min chart, the cursor disappears to the left. Can I make the 2 minute roll back to the time shown on the 5 minute chart? TX
[2014-07-19 20:27:22]
This can be done with Tools >> Synchronize Charts. Refer to:
https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#GlobalCursor
