Date/Time: Thu, 09 Jan 2025 19:17:37 +0000
duplicitous charts
View Count: 670
[2016-08-09 18:05:20] |
User780238 - Posts: 45 |
When I start up Sierra Charts I have 5-6 timeframe charts for each future. When it loads I am getting duplicate charts for the same future contract. For instance I will get two 3 minute charts, two 5 minutes, two 15 minute etc. They load after the original set loads. And they are not exact duplicates more like a template. Any idea how I can correct this from happening?
[2016-08-09 18:15:28] |
You can just simply go to whatever charts that you do not want to see and select File >> Close Active Window. After that select File >> Save. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-08-09 18:15:41
