Date/Time: Thu, 09 Jan 2025 19:13:58 +0000
bid/ask line and difference value on chart
View Count: 1076
[2016-08-09 15:03:58] |
User513952 - Posts: 84 |
How can I set the bid/ask value on the chart and let then align to the right of chart?
[2016-08-09 18:21:19] |
Use the Bid and Ask Prices study: https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s355 And set the Draw Styles for the two Subgraphs to Subgraph Name and Value Labels Only: Chart Studies: Subgraph Name and Value Labels Only (ACSIL: DRAWSTYLE_SUBGRAPH_NAME_AND_VALUE_LABELS_ONLY) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-08-09 20:47:41] |
hi, I did it not using study instead of other method shown in the picture, but I forgot how to do it. Please help me. |
[2016-08-09 22:27:58] |
You can use this command on the Chart menu: Chart Menu: Show Bid and Ask Lines (Chart menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-08-09 23:32:41] |
Hi: Please make me know how to make the bid/ask spread visible as shown on my attached picture. Thanks |
[2016-08-10 00:46:07] |
There is no attached picture.
