Date/Time: Thu, 09 Jan 2025 18:50:58 +0000
OCO Order question
View Count: 824
[2016-08-09 07:32:22]
GPST10 - Posts: 139
Can somebody confirm the OCO doesn't function with gold and crude? I am sending attached orders by position and it worked under SIM but not doing so in live. The way I test is I just cancel one and other still stays, Any information on this? Using cqg
[2016-08-09 07:50:33]
The behavior of OCO orders is not going to be dependent upon the symbol.
It could very well be that when you cancel one of the orders that CQG is not canceling the other order in the OCO group.
Date Time Of Last Edit: 2016-08-09 07:50:55
[2016-08-09 15:19:35]
GPST10 - Posts: 139
how to achieve functionality? i'm not be so concerned about server side or not in this case, i would like to have OCO even if its resides on my machine. Can I get working it?
[2016-08-09 16:38:51]
Disable Global Settings >>General Trade Settings >> Use Server-Side OCO and Bracket Orders.
[2016-08-09 17:10:58]
GPST10 - Posts: 139
yep,
thanks
