Date/Time: Thu, 09 Jan 2025 19:30:16 +0000
tool values window is black
View Count: 1285
[2016-08-08 18:19:04]
onnb - Posts: 662
My tools value window has gone completely black - I don't see any values.
Any idea why that might be?
[2016-08-08 18:51:49]
You need to use the Chart Values tool to see the data:
http://www.sierrachart.com/index.php?page=doc/Tools.html#ChartValues
Also check the color settings:
http://www.sierrachart.com/index.php?page=doc/Tools.html#ColorSettingsToolValuesWindow
[2016-08-08 19:36:40]
onnb - Posts: 662
The Chart Values shows fine. I think the chart Values only shows the values of the last bar
I normally don't use it.
I normally use the Tools Value (Alt+V) with the cross hair so I can see historic values
The Tools Value is black regardless of color settings. I can't the main price data as well as any subgraphs
I also don't see the compact tools values widnow
https://dl.dropboxusercontent.com/u/9913454/tmp/Screen%20Capture%20%23490.png
[2016-08-08 20:35:02]
So do you actually have the Chart Values tool active at this time and the Tool Values window is still blank? It is next to impossible for that to be a problem. We have never heard of that before. Try restarting Sierra Chart.
For instructions to use the Compact Tool Values Window, refer to:
Chart Drawing Tools: Compact Tool Values Window
If it is not visible, refer to:
Chart Drawing Tools: Cannot See Values Windows?
Date Time Of Last Edit: 2016-08-08 20:35:47
