Date/Time: Thu, 09 Jan 2025 18:53:30 +0000
Help w/ Alert
View Count: 705
[2016-08-08 12:55:04]
User28914 - Posts: 87
I am having a problem with getting alerts to work on the MACD crossover system . my current attempt is =CROSSOVER(SG1,SG2) which from what I've seen should be ok as the ID number is at the top of the settings box . I get signals but not alerts . Can you see a mistake as Its starting to do my head in .
In my Study Settings > Alerts tab and I have Enabled checked and the Alert Sound is correct.
It draws the study but no Alert given.
Any thoughts?
[2016-08-08 13:19:03]
I figured out one thing but not this:
I changed the code to =CROSSOVER(ID14.SG1,SG2) and it seems to work but only on the short side cross. ID14 is the actual MACD indicator.
How do I get it to long side too?
[2016-08-08 15:54:52]
For the MACD Crossover System study you need to use this Alert Formula:
= OR(SG1>0,SG2>0)
Use this formula directly on the study itself:
Study/Chart Alerts And Scanning: To Enter an Alert Condition on a Study
