Date/Time: Thu, 09 Jan 2025 19:05:45 +0000
volume bars placed at the bottom of a candlestick chart
View Count: 659
[2016-08-08 11:08:09] |
User780238 - Posts: 45 |
How do you get Volume bars on the bottom of a Candlestick chart? Thanks
[2016-08-08 16:04:46] |
You just add the "Volume" study to the chart. Refer to: Chart Studies: Adding/Modifying Chart Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
