Date/Time: Thu, 19 Sep 2024 21:34:32 +0000
Running SierraChart on more than one PC
View Count: 1410
[2013-07-19 08:34:39] |
User96105 - Posts: 113 |
Hi. I use SierraChart on my desktop PC, but will shortly be going on holiday. Can I copy the platform and my charts to my laptop? What is the best way to do this? Many thanks |
[2013-07-19 09:35:11] |
Yes you can do this. Follow the instructions in help topic 15 here: Http://www.sierrachart.com/index.php?l=doc/helpdetails15.html Login to the new installation of Sierra Chart using your same Account Name and Password. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-07-19 09:35:28
[2013-07-19 21:27:12] |
Great, many thanks...
