Date/Time: Thu, 09 Jan 2025 19:14:27 +0000
Volume
View Count: 719
[2016-08-07 13:14:48]
User529762 - Posts: 25
I have study , 'Volume colour based on bar close', however I get a down bar close with a Green volume bar , this only happens sometimes but would like to know if I can correct this error? I also sometimes get the opposite so up green candle with Red volume?
[2016-08-07 18:48:14]
[2016-08-08 12:40:19]
http://www.sierrachart.com/image.php?Image=1470659931578.png
[2016-08-08 16:19:00]
Do not use that study. It is not appropriate for Candlestick bars.
You need to use the standard "Volume" study with the default Auto Coloring setting:
https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s8
Date Time Of Last Edit: 2016-08-08 16:19:17
