Date/Time: Thu, 09 Jan 2025 18:58:42 +0000
Notepad
View Count: 1010
[2016-08-05 20:29:47] |
Kinobe - Posts: 86 |
hi is there a way to get a notepad or something similar to insert text in a seperate window which is linked to a symbol? thank you, |
[2016-08-05 20:34:21] |
We do not understand this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-08-05 20:34:32
[2016-08-08 00:14:42] |
here is attached tradingview example for textnote: the notepad is linked to the symbol. So I can retreive the text I wrote for each symbol when I check its chart. |
textnotes.jpg / V - Attached On 2016-08-08 00:12:22 UTC - Size: 431.22 KB - 309 views |
[2016-08-09 06:13:10] |
You can write text directly on a chart: Chart Drawing Tools: Type Text | Stationary Text Quote Boards also support Comments. Refer to: Getting Quotes: Setting Comments on Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
