Date/Time: Thu, 09 Jan 2025 08:56:14 +0000
Can you add Analysis to this
View Count: 700
[2016-08-05 15:59:33] |
User623839 - Posts: 108 |
I would like to be able to switch to this from my shortcut menu and not the top menu I'm surprised it wasn't in the list given the things that are. |
Screen Shot 08-05-16 at 10.57 AM.PNG / V - Attached On 2016-08-05 15:59:23 UTC - Size: 16.55 KB - 237 views |
[2016-08-05 18:00:51] |
You cannot add "Analysis". However, you will always see "Study Settings" listed on the Chart shortcut menu which lets you change the settings for existing studies on the chart.
[2016-08-05 19:35:26] |
LOL Thanks anyway
