Date/Time: Fri, 10 Jan 2025 09:06:59 +0000
Trailing stop
View Count: 745
[2016-08-05 14:31:26]
trader1 - Posts: 128
Is it possible to have a trading DOM order that consists only of a limit entry and a trailing stop (with no target)? If so, how do I set that up?
Thanks.
[2016-08-05 17:52:40]
Yes. You just need to setup one Attached Order that is a Trailing Stop:
Attached Orders: Using Attached Orders and Attached Order Settings
Do not use a Target order.
[2016-09-06 15:22:46]
Is it possible to add a stop after the order has filled?
Thanks.
[2016-09-06 17:46:49]
Yes. You just simply submit the order as a single Stop order. Refer to this page for instructions:
http://www.sierrachart.com/index.php?page=doc/ChartTrading.html
